Cast and Crew images not showing
When I connect to my nas via SMB all cast and crew images show but when I use the plex server on the same nas with the same media not all the images show. Is this a bug or is something wrong with my plex server.
Can you try installing today’s 7.1.1 update?
You can also try running ‘Scan for Changes’ in Infuse > Settings > Library.
Updated and did the scan. Nothing changes. Still same thing. Some art shows and some art doesn’t. Question, is it pulling the images from the plex server or from TMDB.
When using Plex (or Emby/Jellyfin) Infuse will pull all artwork from the Plex server.
If you’re using a direct connection like SMB, then Infuse will fetch all of its own images from TMDb.
Ok, i have my plex server setup to put metadata from TMDB and the images show on the plex server and the plex app. Is there anything else I can try.
Can you try installing today’s 7.1.2 update?
This has a handful of fixes for Plex cast/crew lists.
After deleting the metadata it works. Thanks
