Hello, James.
Can you check one more file, please. Uploaded Comedy.club.201.avi
Selecting Auto or 4:3 mode changes nothing, movie is still stretched to 16:9.
Works on PC and in another app.
Can you describe what you are trying to do?
This appears to be a 704x400 (1.76:1) video, which should nearly fill the entire screen of a 16:9 TV.
I see now, so problem is in file, someone created stretched version of 4:3 show? Strange, but clicking 4:3 does nothing to screen in Infuse. Added screenshot of another app.
The aspect ratio works with the zoom option to allow for more precise cropping and zooming. Unfortunately, it cannot be used to squeeze incorrectly encoded videos at this time.
For example, if you had a 4:3 video which was encoded in a 16:9 format with black bars on the side, you could select the 4:3 aspect ratio option and either stretch or crop the video to fill the screen. This is also very useful for widescreen movies, as it allows you to effectively crop out some (or all) of the encoded black bars.
Got it, thank you again.
