Can't select DTS using m4v
Here is one example:
Original file (MKV) only one Audio file:
[code]Audio
Format                                   : DTS
Format/Info                              : Digital Theater Systems
Codec ID                                 : A_DTS
Duration                                 : 2h 24mn
Bit rate mode                            : Constant
Bit rate                                 : 1 510 Kbps
Channel(s)                               : 6 channels
Channel positions                        : Front: L C R, Side: L R, LFE
Sampling rate                            : 48.0 KHz
Bit depth                                : 24 bits
Compression mode                         : Lossy
Stream size                              : 1.52 GiB (19%)
Default                                  : Yes
Forced                                   : No[/code]
Here is the same file after remixing using subler with tree audio files
[code]Audio #1
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Mode extension                           : CM (complete main)
Codec ID                                 : ac-3
Duration                                 : 2h 24mn
Bit rate                                 : 576 Kbps
Bit depth                                : 16 bits
Stream size                              : 594 MiB (7%)
Language                                 : English
Encoded date                             : UTC 2012-10-28 16:26:29
Tagged date                              : UTC 2012-10-28 16:33:32
Audio #2
Format                                   : DTS
Codec ID                                 : A9
Duration                                 : 2h 24mn
Bit depth                                : 24 bits
Stream size                              : 1.52 GiB (18%)
Language                                 : English
Tagged date                              : UTC 2012-10-28 16:38:41
Audio #3
Format                                   : AAC
Format/Info                              : Advanced Audio Codec
Format profile                           : LC
Codec ID                                 : 40
Duration                                 : 2h 24mn
Bit rate mode                            : Variable
Bit rate                                 : 197 Kbps
Maximum bit rate                         : 313 Kbps
Channel(s)                               : 2 channels
Channel positions                        : Front: L R
Stream size                              : 204 MiB (2%)
Language                                 : English
Tagged date                              : UTC 2012-10-28 16:43:07[/code]
Only Audio 1 or 3 is selectable (press and hold the center button to open the popup menu).
Edit:
Original MKV file
DTS Codec ID is A_DTS
M4V file using passthrough with subler
DTS Codec ID is A9
*** BUMP ***
