Can't reset settings on ATV2
My jailbroken ATV2 (4.3) acts as if Parental Controls are enabled, which I’m sure I never set since I live alone. I’m trying to reset settings (not a full restore since unthetered iOS 5 jailbreak has not yet neen released) but the ATV2 hangs on the apple logo with the progress bar below.
Is there any other way to do the parental control reset?
Thanks.
No suggestions?
Found a solution to get the parental control PIN:
  1. Copied com.apple.frontrow.plist file from ATV to PC
  2. Used plutil -convert xml1 <filename> to convert to xml on win xp
  3. Renamed the file to .xml
  4. Opened the xml file and the PIN is listed after ParentalControlAccessPin
