can't mount
Hello,
I've followed the demo video to sharing a folder for streaming through NitoTV but I can't get it to mount.
I'm using the SMB protocol, and trying to mount the Movies folder from my macbook pro.  I have shared this folder and use my admin username / pswd to login for the ATV flash setup.  If it helps, i will take a screen shot from the apple TV.
Anyone help?
It may be an issue with one of the share point settings being used on the AppleTV. If you're able to post or PM your share point settings I can review them for you.
