Can't make working flash drive!!
I have been using a Sony 1GB microvault for the past year with no problems. Today I can not get a working drive. I have tried a couple of other drives as well without success.
I tried creating the drive from the install atv program in applications as well as from the DMG file. I looked at the drive after creation and all looks alright, only 1 partition etc.
I have 3 ATVs and none of them will boot from one of these new drives. 2 ATVs have a previous flash and the 3rd has just been updated and is a clean install.
I have a macbook pro running latest leopard.
Can anyone help me with this?
Chris
I made this post a while ago:
i have the 2GB sony microvault - doesnt work either. wont boot.
I have the same problem too. ATV could not boot from USB stick which one created atv flash 3.6.2 on Mac OS X 10.6.
I’m getting following error after patch stick creation
“unable to change to apple tv mode. unmount failed”
Is that compatibility problem with Mac OS X 10.6?
Problem solved… aTV Flash incompatible with MacOS X 10.6 :slight_smile:
Thanks in advance.
cryptooth…
Snow Leopard compatibility coming soon. :slight_smile:
[UPDATE] Snow Leopard Compatibility is featured in aTV Flash 3.6.3.
