I installed mirow with the installer tried to open front row would not open restart computer still won't open? Help please.
Do you know if the the DVDpedia application was previously installed?
yes I did have the dvdpedia installed what should I do then? thank you for your response
Update I followed the instructions to remove the plugin dvdpedia and sure enough I've got front row now with all the mirow features. I like it allot ,still playn with everything. Will I be able to get back dvdpedia I really enjoy that plugin? Thanks
