last year I managed to jailbreak my ATV2 with seasonpass.
a few weeks back I unfortunately pressed the restart button on ATV2. now seasonpass has gone.
I tried re installing seasonpass several times but with no luck.
Thats what happens:
I run seasonpass, it create the IPSW SP file, i plug the ATV2, i manage to switch it to DFU mode, itunes (11) gets started but it doesn’t find the IPSW PS automatically. I so select it manually by clicking Alt +Restore and point it to the IPSW SP file. It ask me if I want it to restore to the 5.0.2 version, I click yes, and it then takes some time to restore it. After a while itunes gives me the message that the ATV has been restored to manufacturer settings. However when I switch to Seasonpass window, I still get the message that itunes is running the script ecc and won’t get further.
can anyone tell me what is wrong and what should i do?
use Ifaith to put it in dfu mode(or if u don’t know how just run season pass all over again). then open itunes after it recognize the apple tv ■■■■/alt restore make sure you select the 5.0.2 assign from sp(season pass) bcuz u have 2 files on your computer it will have sp in the line. it’s likely u r just selecting the regular 5.0.2 file that’s on your computer
Hold Option and click Restore in iTunes. Browse to ~/Library/Application Support/Seas0nPass/Firmware/. Choose the IPSW in there and wait for it to restore. Done!
