Can't get external audio to work
Hello, how exactly does the external audio feature work? I have movie.mkv and movie.eac3 in the same folder, but it doesn’t detect the audio on infuse.
I’m running Plex and tried with and without direct mode active.
Unfortunately, Plex does not support external audio tracks at this time. But if you are able to connect to this device directly (using something like SMB, NFS, WebDAV, etc…) then Infuse will be able to pick up these external audio track files and use them with the corresponding videos.
