can't create Flash- Drive
hi:
I just purchased the new ATV Flash 4.0.1
downloaded the new image from apple
temp.dmg 240,102KB
then it says Image copy to my USB drive ok,
but I don’t see any files on my USB , i’m running Windows XP,
it’s a 4GB USB flash drive, I alreaedy formatted with the suggested HP formatting tool,
any idea ?
are we, as Windows user, be able to see the files on the Flash drive ?
some updates.
actually although I can’t see the files, the files are there in Mac Format,
that’s why my PC can’t see it.
Once i plugin to Apple TV, it install ATV Flash successfully.
