Can't connect pCloud to Infuse
Hello,
I am trying to connect pCloud to a third party app (Infuse). It used to work without a problem before. For some reason, I had to remove the connection but I can’t proceed to connect to it again.
I tried to do it on my Mac through several browsers (Arc, Safari, Chrome) with the ad blockers disabled, and also on my iPhone 11 Pro. The problem occurs every time : from Infuse, when I click the link to connect Infuse to pCloud, the login page loads partially. I just see pCloud’s logo on the page and nothing happens.
The link type is the following :
https://my.pcloud.com/oauth2/authorize?client_id=(hidden)&redirect_uri=infuse-oauth://pcloud&state=(hidden)&response_type=code&force_reapprove=true
What can I do ?
Thanks for your help.
I don’t use any cloud services but you may want to read through the users guide and see if there are any hints to help you out.
Somehow, I tried again today and this time the page wasn’t blank ! It’s working again.
Thanks :slight_smile:
This seems to be more common with pCloud, users seeing issues with connecting with this service. They may be having problems and working on them.
Thanks for the update! :+1:
