HI guys,
This is a complete mystery to me. No matter what I do, some movies are not correctly sorted in Favorites folder.
Important : I am using Local Metadata only (I have nfo files for each movie, correctly named after each movie file).
Here is an example :
I have 3 movies named :
Angelique 1 - Marquise des Anges
Angelique 2 - Merveilleuse Angelique
Angelique 3 - Angelique et le Roy
I cannot get these to display in the correct order in Favorite view : Angelique 3 comes first, before Angelique 1.
In the nfo files, I have set all titles to the same to be sure, as I did not know which one Infuse is using for sorting the movies in Favorites view.
So I have in my 3 nfo files :
- File Angelique 1 - Marquise des Anges (1964).nfo
- File Angelique 2 - Merveilleuse Angelique (1964).nfo
- File Angelique 3 - Angelique et le Roy (1965).nfo
Everything seems ok, I see no way Infuse could display these movies in the wrong order as all titles and filenames are aligned, and still, it displays Angelique 3 before Angelique 1, and Angelique 2 gets displayed after 6 other movies on the screen (Cars, Dumbo, Final FAntasy, Freakt Friday.
I even tried to remove the favorites and recreate it on the folder containing the movies, result is always the same.
I am getting crazy with this. Can you help ?
