Cannot reach peak brightness in HDR on Vision Pro (VP9)
Infuse doesn’t seems able to reach the peak brightness in HDR mode on Vision Pro. I also noticed the content brightness is affected by brightness slider in Vision Pro.
As you can see two images I captured in low brightness and max brightness. The roof tile brightness is very different. In Safari on the other hand, the brightness slider doesn’t seems affect the overall brightness(at least pretty minimal).
I suspect to reach maximum brightness must be in immserive mode with AVKit, which is the one Safari is using. Since Safari is providing same result in windowed mode. Only reach high brightness when entered immersive mode.
I also tried YouTube native app to make sure it isn’t the video format issue or HDR isn’t triggered on Infuse. Since the video infuse is ripped using yt-dlp with vp9 codec. May be different from what safari is playing. So I sideloaded iPadOS version of YouTube app, there’s no immersive environment in it. As you can see it provides similar result as Infuse. YouTube apps also saying it’s played in HDR mode. So it also confirmed that VisionOS might not allow to reach peak brightness when not inside the immersive environment built by AVKit.
I forgot to test YouTube app in low brightness. But the result is pretty obviously since safari’s tile is showing at 255,255,255(might be clipped by screen recording since it only support SDR) and YouTube not even close to 255,255,255
Unfortunately, HDR VP9 content has limited support at this time. Most current Apple hardware has support for VP9, but the required APIs are private and can only be used by the YouTube and Safari apps.
Playing HDR HEVC content should allow you to have better results in Infuse.
Thanks for quick response.
I repeated the test in HEVC profile 8 Dolby Vision again. I’m still getting the similar result. The brightness of video in Infuse still lower than Safari, as well as the preview from Apple. And also affected by brightness slider, even at max brightness the result still dimmer than the others.
However I noticed the content doesn’t have to be in immersive mode like YouTube. Both Safari(as long as it’s in fullscreen) and Preview app showing the peak brightness in windowed mode.
Also it seems like brightness slider does change the brightness of video in Safari and Preview app. However when I maxed out the brightness the peak brightness of video gets lower in Safari and Preview app. It’s probably related to ABL with micro-oled.
Can you try enabling Immersive Mode in Infuse?
I tried that. But I cannot notice any difference.
If you’re able to send in one of the files you are playing we can take a deeper look. Thanks.
I have submitted. You can check it out. But I think this issue might not limited to single format.
I don’t think this is limited to VP9. What ‘s been described is very similar to what I posted below.
This is probably an HDR tone mapping issue
https://community.firecore.com/t/hdr-looks-flat-on-vision-pro-in-immersive-elevated-blacks/57943
@james Any findings on this please? Please help fixing this brightness issue. Currently the app is unusable.
@james Is there any update on this?
@james we aren’t expecting an immediate fix. Just update us with the plans, at least. I mean why does this have to be ignored?
There is a pattern to rush features out that are at 80% good enough with the promise of fixing the bugs at a later day. The problem is some of those turned out to be later years instead.
And it is true of coding, the more features you add the more bugs you’re going to introduce in other areas.
I think core functionality bugs like video quality shouldn’t be left for another day in my opinion, but it is what it is.
@james - I have some new findings.
I tried playing the same movie on two different copies one is an SDR and the other is HDR.
And both look exactly the same, which explains why HDR looks pretty flat on the Vision Pro. Seems like the HDR was broken after the VisionOS 26 release. And maybe you never got a chance to look into that. Please dedicate some time to at least checking that issue. Fixing is something you can plan later. But at least have a look into that issue and update us. I badly want Infuse to have this fix.
Sorry, I missed this. Are you able to share the name of the file which was sent in?
I forgot the name, I think it supposed to be 4K60p.mov if I didn’t change the filename.
The file is available on Kodi samples named Dolby Vision w/embedded HLG HEVC 60fps (MOV, Photography Blog’s iPhone 13 Pro raw 4K footage)
