Cannot load subtitle with same name
I used Alist to link the cloud drive with WebDAV (HTTPS).
I put an MKV file and an SRT file with the same name, but Infuse cannot recognize the subtitle file.
I tried simplifying the names to use 13.mkv and 13.srt, but it didn’t work.
Infuse Pro 8.1.6
iOS 18.5
Alist v3.45.0
Are these subtitle files listed if you browse this share through the Infuse > Settings > Add Files > (share name) screen?
Yup, I downloaded the files to my local drive, but Infuse is still refusing to load the subtitles. Any ideas what’s going wrong?
I tried different videos and subtitle files, but Infuse still doesn’t load them. I tried ASS files and then converted them to SRT, but it still didn’t work.
I tried to play the same files on Windows with MPV Player, and the subtitles work.
I found the problem in Alist (WebDAV): there’s a setting to disable media links, and after enabling this option, everything works fine.
But I’m not sure why there’s a problem when playing videos on the hard drive.
