Cannot connect to iTunes
Hello all,
JB'ed and installed Flash Black yesterday.
XBMC etc. all working perfectly.
What's not working at all, are the standard features...
I can play songs off my MBP on the ATV2.
But nothing/nada/zip else.
It keeps on telling me I have not purchased any songs. No library reflects under the Computer's tab. So basically - my MBP can find the ATV, in order to utilise Airplay - but Homesharing is simply not happening...
Any suggestions? Super frustrating...
[EDIT]
What does a “reset” do, as opposed to a “restart”? Will the former wipe/break my JB - or is it worth a try, to see if that fixes things?
Have you actually entered your iTunes log in details on the ATV2?
[quote="itimpi"]
[/quote]
Hi itimpi,
Appreciate the reply.
I have signed in, and signed-out - and back in again - several times already. Things are behaving a bit strangely, to be honest.
Last night, for the first time, I had a look at the Photo Stream - and it started pulling photos in. Fired it up this morning again, and it's started loading them again. Also received an automated email from Apple, confirming that a ATV2 had signed into my iCloud account, which is obviously a good sign (and true).
But nothing is displayed in my Songs tab. I do recall a message flashing up the first time I went in, saying it was synching. I might have interrupted that, by jumping out (I presumed it went on in the background - appears not to?) - and since then, nothing.
ALSO cannot get access to my HomeSharing library. As mentioned, I can Airplay from iPad/iPhone/iTunes TO the ATV - but it's not picking up the library. Signed in an out, reset and restarted Homesharing - nothing.
This is why I'm curious as to what a RESET on the ATV2 does... Should I try it? Or will it kill the JB?
Managed to get iTunes working.
Signed out and deleted all my account settings - did the same with my WiFi.
Restarted - did everything again - and it took.
Homesharing is still proving problematic - but will see what I can get right by jiggling around with Sign In/Sign Out...
