Can’t seem to gain a secure connection to Plex
I have been testing infuse and love the app, but why doesn’t it load securely under https? When connected via any alternative app, it always connects secure, but with infuse it doesn’t.
Infuse will use a secure connection to the Plex server if one is available, but due to server configuration issues this may not always be possible.
I will note, Infuse uses Apple’s certificate validation process and this will not accept self-signed certificates as valid. Other apps may or may not be using this same certificate validation process so the results you see there may vary.
