can not upgrade AppleTV to 2.2
I installed the aTV Flash prior to updating the software. And I selected the ‘disable auto-update’ function. The Apple TV Will not update to 2.2. How do I disable the “disable also-update” function? (3.3.4 installed)
You can reinstall the aTV Flash with the update disabling feature DESELECTED. This will re-enable the update feature.
