Hi - can someone please clarify these 4 questions for me? Please give me as much detail as possible so that I understand it fully.
(My set up Synology DS918+ NAS with my rips on it–>APTV4K with infuse Pro -->Denon X3500H amp)
Can infuse pro play my rips with DTS-HD Master Audio and Dolby TrueHD sound tracks through my newly purchased AV receiver?
I read somewhere on this forum before that there was a bug with tvOS which broke the passthrough - and if so, has this been fixed already?
I know infuse Pro is supposed to be able to send lossless DTS-HD Master Audio and Dolby TrueHD sound tracks via LPCM (software decode) to a receiver, is the software decoding any inferior in performance compared to the same soundtrack being transmitted via a standalone media player which then is decoded via the receivers hardware?
is there any difference in sound quality in infuse pro sending DTS-HD Master Audio and Dolby TrueHD sound track via LPCM?
A friend of mine has said to me he is not a fan of the infuse pro because the player should only decode the video and the receiver should decode the audio. Does it matter who is doing the decoding and why?
Infuse does support DTS-HD MA and TrueHD, and the full lossless audio will be sent to your receiver as LPCM.
The decoding process itself is standardized between all Dolby/DTS certified products (Infuse is certified and licensed for both) so in the end there is no difference whether this decoding is done by Infuse or your receiver. A bit more info on this can be found here. Audio Options & Capabilities – Firecore Support
The only real caveat is Infuse is not able to support Atmos or DTS:X due to limitations in tvOS, but this is something we are encouraging Apple to change. A few more details can be found here. Help get (more) Dolby Atmos on Apple TV
So if Infuse can send DTS-HD MA and Dolby TrueHD via Apple TV to AV Receiver, how do I know it is actually doing that and PCM (in my case a Yamaha AV) is playing actually lossless and not something else? Is there a way to proof?
The proof is in the technical details. Infuse licenses the codecs and decodes the audio and packages it as Linear PCM which is then sent to your receiver.
Additionally if you scroll to the bottom of here under the pro section Infuse 7 - An Elegant Video Player | Firecore
“ HD quality audio
Hear every detail with added support for 24-bit Dolby TrueHD and DTS-HD MA audio.”
Infuse won’t show anything. The pro version is licensed for TrueHD and DTS-HD and any movies with these audio files will be treated as such. While a movie is playing you can swipe down and select the audio track you want played.
I suggest reading the Dolby atmos thread at the top of the forum. Infuse will read the TrueHD track and decode it to PCM. Atmos metadata is stripped out because the AppleTV doesn’t support bitstreaming which is required for TrueHD with atmos.
Netflix encodes everything as Dolby digital plus with atmos.
This is good info thanks, so there is no quality loss with dolby true hd and DTS HD MA tracks played through infuse, its just infuse sends it pre decoded as PCM to AVR rather passthrough ?
Also can you pls implement the Atmos which works with DD+ tracks, like Netflix and MRMC also does Atmos with DD+tracks, it even works in TVOS 12.4
