I have the same problem. How can we work this out - will I get a refund (as I have the original 4.0 on my Apple TV and therefore had to assume that everything works fine) or will there be a new Jailbreak soon? Should I still stay on 4.0 or can I upgrade to 4.1 as 4.0 is now useless anyway? And finally: Don’t know about SHSH, but will TinyUmbrella and saving these SHSH still help me to get it working?
Would be nice if someone could help us out. Thanks for your efforts.
my apple tv is 4.1, I had created the custom ipsw 4.1 file but itunes say it cant restore the custom file as my Apple TV is not eligible… Thats really bad I bought my micro usb cable yesterday, got my licence Firecore for my apple tv then cant use it ! … how long will it takes to solve this problem ? shoud I update to 4.2 on my apple tv then wait for the dev team to jailbreak this 4.2 version before being able to install the firecore application on it ? or do you proceed to refund in the mean time ? I took a one year update for your program but days are running and I cant use it … You should really mention this problem before we buy your software.
I have the same exact issue... this really should have been disclosed as the advertisement was how incredibly "easy" it was to set up. If I knew nothing about computers, this would not be easy.
I also have this problem. My apple tv has 4.0 on it. I did not update and fallowed the directions exactly. Yet it failed to work. Please let me know how to fix this.
Everyone’s waiting for DevTeam to provide an untethered jailbreak for AppleTV on iOS 4.2.1
In the meantime, you could try to do a tethered jailbreak, but you really have to know what you are doing and have a Mac running Snow Leopard and a Windows virtual machine close to the AppleTV box.
Not for the fainthearted and it took me 2 weeks to get it right - needed iReb to kill Error 1600, use Windows to restore the firmware and had to reinstall stock firmware first if I got Error 21.
But I now have AppleTV with aTV Flash and AirPlay all running beautifully.
