BUG: Wrong cast images (infuse with plex)
Like the title states, i have infuse showing me different cast when connected to plex. The same movie viewed directly without plex shows correct cast. So the bug must be somewhere btn plex and infuse. I’ll update with an example screenshot later on.
What site is Plex using for metadata?
plex uses tmdb… all the metadata is the same just the images and the actor is wrong as you can see its showing too shorts image instead of cate blanchett lol and some images that are visible on Plex are missing in Infuse…when I add the movie directly to Infuse the cast is as should be… so somewhere btn plex and infuse communicating seems to be a bug and its not just this movie
