This evening my infuse ( last version ) is having a hard time with a movie ( The Woman King 2022 ).
My main page on appleTV4K displays " Unseen movies " with the sort order " by date ".
After adding the movie, I saw that it did not shows on my main page.
But still invisible on the main screen.
I tried to change the sort order to " Release Date " to test, but even with that option the movie won’t show in the 2022 movies, then I reach 2021…
Tried to reboot Infuse, my AppleTV. Same.
I never saw something like that before, so I don’t know what is triggering that behavior.
Infuse looks at the created/modified dates for the “Recently Added” sorting so if it was created before the others even though you just added it, it’s position will be farther back.
If you think that the Recently Added list should be in the order of when it’s added to Infuse instead of using the file created/modified date you can add your support to that feature request here.
Hey NCB !
That’s why I tried to sort by " Release Date " to confirm that there is something wrong.
By sorting like this, the movie should appear on the main page as a 2022 movie but it’s not the case.
Sorry guys, the bug is still there ( updated to 7.4.9 (4321).
I tried to reboot infuse, reboot the AppleTV, refresh files, change order ‘by date’ > ‘by release date’. Nothing.
Also, seems worse because I have a brand new movie file, which was in first position in my home screen all the week ( ‘by date’ sorting ), and with 7.4.9 it vanished too.
For me it looks like it’s fixed. The issue I saw on the previous version is that any TV show or movie that started with the word “The” wouldn’t show in the list of 29 items on the home screen but would show in the first 30 on the see all.
If you’re willing to take the time, maybe list the 29 files in the pinned list and then the first 30 of the see all screen.
That was why you weren’t seeing “The Woman King” on the home screen list but it did show in the first 30 of the see all.
I’ll correct my last post. It’s not fixed but it’s better. Still some anomalies on what Infuse shows on the pinned list vs what it shows for the first 30 in the “See All” for that same pinned list. FYI @james
Here are the list of missing items.
Note that before the last update (7.4.9), only " The Woman King " was missing. The movie " The Outfit ", one of the items with ‘The’, was displayed well on the home screen.
Hope this helps.
Thanks for that! I did about the same thing and I can’t see what the logic is in what gets displayed and what doesn’t so I hope @james can hammer out what’s going on.
