Bug: scrolling issue on Classic detail view
Since 8.4 I’ve noticed that I cannot scroll down the detail view (classic) past cast and crew to the watching stri. If I try to scroll down, the view bounces back up - although it seems that the selection actually goes into the watching list; if i click OK it will play a movie from there (although I can’t see what it selected.
This is also true on movies that have extras, I can’t scroll down past the extras to the lower strip (whichever it might be - recently added, watching, etc).
All in all, there’s a lot of strangeness going on in the detail view, at least the classic. Please take a look. Thanks! Like the new extras feature, I was just getting into putting those into my PMS.
-Alan
Are you still seeing this issue in 8.4.2?
Yes, no improvement on 8.4.2.
From the last two Infuse update if you have set the Classic View, it is impossible to scroll down the page of a movie that is a part of a collection to select another movie of the same collection.
Here a similar problem: no way to scroll down to select other titles in collection.
In the classic interface, for movies only, you can’t scroll past the list of actors to view the list of movies. This works for TV shows and in other interfaces.
I moved your post to an already running thread discussing this issue. :wink:
This should be fixed in today’s 8.4.3 update. :slight_smile:
A quick check of the new version looks good to me! Thanks.
