Bug: double vision Logo
Infuse (8.0.4) repaints a tv series logo with a horizontal shift, creating a double vision effect. To reproduce:
  • Go to an episode’s detailed view in the Watching list.
  • Push the Siri Remote ‘TV’ button to go to the Apple TV Desktop.
  • Re-enter Infuse. The logo is now distorted.
I can’t seem to replicate this here.
Are you using a media server like Emby, Jellyfin, or Plex - or is this a direct connection like SMB, NFS, WebDAV?
I’ve had this issue as well. I think it only happens when you’re on a movie/tv show details page, leave the app, and then come back to it, you get a double-vision of the logo.
  1. Go to a movies or TV show detail page where it displays the information about the movie/TV episode, fan art, logo, etc…
  2. Leave the Infuse app and load another AppleTV app
  3. Go back to the Infuse app
  4. The once-suspended Infuse app will display where you left off (the movie/TV episode details page) but the logo seemed to have been loaded twice in different positions (or the cached logo stayed in one position while the app loaded up the same logo but in a different position)
I hope that helps. If not, I could try and record a video of this bug.
Hi James.
I use SMB. Leaving Infuse suspended and then re-entering should produce the effect.
If it can’t be fixed, it’s no biggie. Just a FYI.
Yes, your description matches my experience.
Here is a recording of the double vision logo. Pretty sure this came with tvOS 18 or Infuse 8.
I’ve noticed this a couple of times, as well. Jellyfin direct mode from apple tv app.
I’ve noticed double logos on ATV today, although they end up one below the other.
Here’s how to reproduce it every time - go to a TV series or movie home page with the logo showing, then double click the TV/home button to bring up the app switcher, switch to another app (or just the apple home page) and then double click the button again and switch back to Infuse. Instant double logo.
This has been resolved in today’s 8.1.3 update. :slight_smile:
Thanks for your patience.
