I’ve read through every post and thread on this here and on other sites over the last couple days, solving this annoying problem. I’m on the latest everything, top of the line PC, great WiFi, aTV4k, etc. What I was running in to since moving up to 4k rips and remuxes, were buffering for the really high bitrate files and a 20-30 start delay for the smaller ones, even though both bitrates were well within all the limits of the network.
Long story short, it’s the Windows SMB implementation. Yes I tried every possible setting and mode, everywhere, with no effect. All I had to do was setup a basic Plex server and connect to it’s share, rather than the SMB shared folder. Instant fix, instant movie start, zero buffering of anything, smooth scrubbing. All over Google Wi-Fi 3 hops away.
If like me you simply store everything on a PC with huge internal storage, do yourself a favor and just switch from a shared folder to Plex. It makes everything better.
I have something similar with MAC. I don’t use Plex - I just share my iMac external hard drive. It is funny, because DVD movies play without a hitch, but short “home movies” I made with Apple iMovie (mp4) are constantly stopping with the whirling time out symbol. It takes maybe 20 seconds to start and the movies don’t play through from beginning to end without pausing to buffer. Even short 2 minute movies. It is worse if my desktop is doing something and using CPU time. It isn’t just 4K movies…it is all home movies. Even ones directly from my camera.
I can upload the same videos to You Tube and they play without a hitch on the Apple TV
I also have a top of the line iMac, google WiFi, apple TV4k, and an LG 4K OLED.
I’m trying exporting video from Adobe Lighroom - if it doesn’t work, I’ll try Plex (not sure I understand what you did)
I was just going to read up on Plex (I have it installed but was not a fan of the user friendliness). I was thinking of only using Plex for my troubled videos (H.264 home videos).
Guys…I don’t know how to make this simpler. YOU DON’T USE THE PLEX APP. You never see it, or the interface. it simply runs to be a share service. Everything is the same, using infuse.
Glad to hear you fixed the issue with the install of Plex. I understand your description - you’re using the Plex server installation simply to serve up the files to the Infuse client.
I’m wondering if a lightweight FTP server (like Filezilla) could have also solved your problem.
OK…I tried Plex on a test - just my short home videos
BEFORE: Constant pauses to refresh buffer. Maybe 30 second wait to start. Totally unwatchable. The family drifts off to other rooms.
AFTER: Non stop video in all but one case. Most videos started immediately and there was no stoppage. One video required a 20 second stoppage initially. And one video stopped once and after buffering completed with no interruption. The family stays.
Today I’ll test it again and also add a couple of DVD/Blu Rays to the mix.
Thanks for the tip kaelaria.
PS: I wasn’t thinking of using the PLEX app…I had read somewhere the user interface suffers when using Plex…may be something else Im thinking of. The home movies came out better with a picture to help.
Hallo guys,
I have the same problem with 1:1 copy of my 4K BD: delayed start and 20 seconds buffering stop every 40 seconds of movie. I don’t have any problem watching the same contents with Egreat A5. My configuration: Fritz!Box 7530 router (FTTH 1Gbps/300Mbps), gigabit wired lan from the router to ATV4K. 8TB HD SATAIII in a USB 3.0 cabinet connected to the USB 3.0 router port. Fritz!NAS works in smb and ftp.
Your bottleneck is probably the USB connection to your drive on the router. I had the same problem with large rips when connecting a USB drive to my router. I moved to a dedicated synology NAS and all my problems went away. The processor on the router just wasn’t fast enough to handle the throughput.
Thanks for your answer. That’s what I thought at first glance, but with Egreat A5, which is an Android 5.1 Media Box, streaming is smoother. Just few minutes ago I modified my share settings from SMB auto to SMB3 and things improved but not as good as Egreat. I’d really like to reach the same quality level and use only ATV4K for all my needs without buying another piece of hardware. Does the upnp protocol guarantee smoother streaming compared to smb?
