have an Apple TV 4K.
I had to perform a reset on my Apple TV because of constant WiFi connectivity issues. Getting errors like incorrect password, and not connecting at all and a total nightmare.
Resetting (factory reset) was the last resort, but it seems to have sorted out the issue.
I see now that my Infuse 6 no longer shows me the buffer indicator on seek bar. It just up and disappeared. Why
It shows up in a lighter grey and tells you that it’s basically cached part of the rest of the movie etc etc.
Also a suggestion, please change the colour of the bugger indicator. Like a transparent green or something. Because the light grey is a little too blendy with the rest of the seek bar.
Thanks for help Love Infuse 6 btw!
