There’s no official support for this card on the AppleTV yet, but we’ve made the latest SVN build of XBMC and required CrystalHD support files available for those who are too curious to wait.
If it’s been ran once, it won’t need to be ran again for CrystalHD to work. If you navigate to the Maintenance > Settings menu, it will give you a status when it was last ran (E.G. Last Ran: 1/8). If will also show if it’s never been ran. (E.G. Last Ran: Never).
Ok it is working now. After second reboot it has gave an option for Crystal HD.
Will you in the future offer the updates for CrystalHD driver, because Davilla will release a lot of bugfixies in the near future?
I honestly believe for this to really hit the mainstream, support needs to be added for Perian. Allowing 1080p to be played through the Native ATV interface.
Lets keep fingers crossed for support of the card to make it into FFmpeg. I’ve just purchased an old ATV off ebay for testing
Yes, updates can be installed just as easily. Navigate back to the Install Extras menu. If the word ‘Update’ appears next to Crystal HD, simply click to install the update.
I struggle with the CrystalHD installation… I have understood that under XBMC we must change the rendering video mode from “Auto” to “Crystal HD” under System → Parameters.
I followed ATV procedure to install CrystalHd drivers and unfortunately I cannot select the “Crystal HD” rendering…
My question is "How can I ensure that the CrystalHD drivers are installed and well configured ?
I have followed the instruction to a Tee , however my 1080p .ts and .mkv files are playing but very choppy. When I go to XBMC downloads all I can see is the xbmc 9.1.1 file to download , is this the latest build ? I keep reading about nightly builds but not sure where and how to download these . Any thoughts or suggestions .
Ok after some update/upgrade the cristalHD card stil doesn’t work and I haven’t got any error messages.
My system is in french, I will try to change the different settings to english.. But I am not convinced…
But is there a way to test the card thru ATVflash ? I start to think that the card could be arrived broken…
To have access to the SVN builds you must be running the latest version of XBMC/Boxee. You can update this item through the Maintenance > Manage Plugins menu.
Once updated, the XBMC SVN builds can be downloaded through the XBMC/Boxee > Downloads menu.
Thanks for your answer : Yes 100% sure I use the last nightly builds. I did a new update yesterday, with no error. XBMC works perfectly except for CrystalHD… The 720p/i or 1080p/i are still very sluggish, impossible to watch a movie… Neither in streaming nor copied locally on the ATV.
I have to underline that the ATVFlash product is very impressive, I can very easely update XBMC, and other software.
