Brightness gesture control issue on iOS 16
On iPadOS 16.1, video brightness is very poorly adjusted if you swipe up and down from the left of the screen. In the last update, the problem was not solved, although I thought someone would notice and write, but apparently they didn’t notice and didn’t write, so I’m writing.
Thanks for the report.
Can you provide a bit more detail on what you are seeing?
The same problem appears to exist on iOS 16.0
Try yourself to increase or decrease the brightness by swiping up or down on the left side of the screen
Same problem here on iOS 16 on a iPhone 12 mini. When I slide up and down on the left side of the screen the brightness sometime doesn’t change at all and them suddenly it goes from 80 to 40 in a jump.
I’m seeing the same thing on an iPhone 13 Pro Max, iOS 16.
Same problem in my iphone 13 pro max
Me to iPhone 14 pro max iOS 16
This has been resolved in today’s 7.4.6 update. :slight_smile:
