Boxee does not start
Hi there,
after using your patchstick (latest version on atv v 3.0.2) i downloaded Boxee Beta, but when i tried to start Boxee i get the following error message:
Cannot launch Boxee from path : /Applications/Boxee.app/Contents/MacOS/Boxee
What do i have to do to get Boxee started ?
Thanks in advance,
K
You may try restarting the AppleTV and re-downloading Boxee beta through the XBMC/Boxee → Downloads menu.
this does not change anything. I also set the atv back to factory settings and re-patched with atv flash. Still the same error message.
What can be done ?
Thanks in advance,
K
