I’ve been noticing for a while now that in Infuse (currently 8.2.5) for Vision OS (26) the bottom window bar (the one to drag the window around) and the dots left and right do not disappear anymore during playback. The playback controls do disappear, though.
Not exactly sure when this started, and if that’s an infuse issue or a visionOS issue. I was on the visionOS developer beta for the past months, so I assumed it’s just a bug in the unfinished OS. But now it’s still there in the final release, and I haven’t noticed any other app to have this issue.
Any idea why this is happening?
Is this going to get fixed? It is super annoying
Indeed very annoying. Unfortunately still present in 8.3…
What I usually do meanwhile is fix the window after the playback start (long ‚press‘ of the x/close button). That turns the bar into a dot, which is less annoying.
Still, hope this to be fixed soon…
That’s a great tip which makes it a bit better.
However. Do the Devs ever reply or take notice of these issues? The software apart from this issue has been great for me though.
I suggest anyone else who finds this annoying to raise a ticket about it with the Devs which is what I have done.
I doubt the Devs actually pay much or any attention to the Forums especially the Vision Pro one.
Yes, I raised the issue via mail as well in September. On 10/6 I got the reply that they will forward the issue to the team. Nothing else since.
One would think that this would be an easy, little fix. Yet multiple new versions passed and it’s still there…
The dev has to be able to first replicate the problem and then make sure the fix doesn’t blow up something else. With only 3 people mentioning it there may be a little time involved in determining what causes it.
This thread is tagged as “researching” so their looking into it.
This issue is still present
Indeed. Sadly… Got it acknowledged many months ago here and via mail. Promises all around that this will be looked at. Then release after release… nothing.
This happens to everybody every time they play a video in Infuse. It’s a simple window attribute that the devs need to set.
That‘s what I thought. Simple fix probably. But as noted above by a mod, not enough people complaining, therefore not important…
Here’s another vision pro user complaining about it. It’s one line of code. In SwiftUI it’s persistentSystemOverlays. Fix it please!!
The issue is still present. Any update on this? It’s been over 6 months now that we have to see this annoying bottom bar during playback that follows the eye movement all the time. Makes this app almost unusable.
I just tried a bunch of other video playback apps for Vision Pro. None of them have this behavior. Yet Infuse wants to be the poster child for this kind of apps in the Apple universe, but can’t get this super annoying behavior fixed in more than half a year.
Now since the last few versions, the home screen got rendered almost unusable as well, with a fixed aspect ratio that barely displays two rows of posters but can’t be changed, just zoomed.
Is someone from the Infuse team actually using this app for themselves, but still can’t get this stuff sorted somehow?
Angry!
It’s been about a year now, release 8.5 is out, and the issue is still there. The bottom window bar still does not fade out during video playback. Why does not one other video playback app for Vision Pro (that I tried) have this issue, but Infuse does not seem to be able to fix this?
