Boot problems
I try to install aTVFlash 3.3.3 and it boots up to what looks like a normal OS X boot screen but instead of the apple there is a circle with a line through it. It then boots to the normal Apple TV and nothing is installed or anything. Any help would be great.
Make sure you are running the aTV Flash installer directly from the downloaded disk image. Do not copy it to your hard drive first.
