Blu-ray and DVD menus
I need this
Not forgotten. It was marked as postponed, which means that there is very little chance to come to fruition because there is a development block. The biggest hurdle is that Bluray menus require Java which isn’t supported by iOS/tvos. DVDs maybe.
Some blu-ray menus require Java but Infuse really has no excuse for not fully supporting DVD menus. At the very least, support for DVD menus is something that should have been implemented years ago.
Would love to see it support blu ray menu and would be able to load local subtitle with BDMV file
The Blu-ray menu is becoming feasible, as other players have already implemented this feature.
Hello. What kind of video player is this? Can it show the BD menu on Apple devices?
I would like to be able to load local subtitle with DBMV file
you can try
From the description, point 7. There is no Java support, and such discs cannot be played with a menu. If I understand correctly, there is support for libbluray. Are there any discs based on libbluray, or do I need to do it myself?
you can install app from above link, because this is very new function , so you can get try and app content have writed support type
Why doesn’t Infuse support BD-J menus on MacOS then? You can use VLC to playback the menus for quite some time now. Of course, VLC doesn’t support HDR but it’s also free. Blu-ray menus as a Mac exclusive feature is better than nothing.
