So I downloaded a movie, but it’s not showing the correct thumbnail. Instead, it’s showing the logo of the website I downloaded it from. Any way to get the correct thumbnail?
Rarbg files have embedded metadata in them. So clear them out or turn off embedded metadata in infuse.
I disabled embedded metadata but the thumbnail shown is still the ones from the movie folder
Embedded metadata on/off doesn’t seem to do anything
After disabling Embedded Metadata, you will need to use the ‘Edit’ option on the affected files to refresh the artwork.
If you prefer to refresh artwork for all items at once, you can use the ‘Clear All Metadata’ option found in Settings.
