Bit rate?
Hello,
It would be nice if you can get info about video and sound bit rates by swipe down the info bar from the top, if that is possible to implement.
+1
+1
+1
+1
+1
+1
+1
I was directed here after asking for a similar feature. I’d like this both while the video is playing but also from the library view.
Things I would like to see are average bitrate, resolution, framerate, codec, container, file size, hdr encoding, and audio details as mentioned in this post.
+1
+1
Displaying bitrate or file size would be great.
This is a feature that is important for me.
I think that is not to difficult to implement.
The info of the file that we are playing when we pull down the option.
The Emby page of movie as all info of the file is just need to copy that!
Other thing is a counter of movies in section…with played and unplayed.
Best regards
Show file info indeed, bitrate, FPS etc thanks
It would great to have a bit rate info screen.
Using Plex on Apple tv when we pull down option and we have the file info detailed.
With the resolution, bitrate and other info detailed.
I think is an importante feature that probably is not dificult to add because just need to import the info from Emby or Plex.
Any news from this new feature @james?
Something like this, but can be better.
No news about this feature?
And IMDb notes on movies ?
I would create a new thread for this. Otherwise it will get lost
