Hi
My last two Apple TV 2 (defo 2nd gen, A1378) have been really messy trying to jailbreak, in fact I havent been able to do it at all, but upon putting the atv back on the TV Im greeted by a huge itunes logo and an indication to put back into itunes.
Im trying to JB to 5.0.2 using ireb to get into DFU mode and the SP ipsw downloaded from seas0npass, but I keep hitting errors like -1 -9 2009(i think it was) etc etc.
Looking on the apple site its saying it could be a USB issue, but Ive used the same tried and tested and always working USB cable for all my jailbreaks (done about 50+ easy with it) and out of 4 Ive had to do this weekend, 2 worked fine (the first two I did) then the last two didnt work and I was met with these errors. I even tried an older version of itunes 10.6 to see if that would help but no luck
If I restore now in 11.1 itunes, what version is it going to upgrade to? 5.1.1? if I do that am I able to roll back to 5.0.2 using the seasonpass ipsw?
I want to get a bit more info before I do this and find that I can only do a tethered jb which I’d rather not do.
