Hi james,
After 6 months of long nights and many frustrating issues with other open source media players, I decided to get a paid product with the hope of have a more stable a solid solution.
First, I have to say the product has great potential and with these bugs fixed and some basic enhancements, I am sure FireCore will takeover the Media Client market for AppleTV.
Here is a list of problems and I have encountered on this beta version.
HD (bluRay) material is impossible to watch. I am using MKV files created with makeMKV. This weekend I tried about 10 different movies with all audio possibilities and they all completely freeze the application or it goes into infinity buffer mode. I think it is a problem with the audio decoding system on the media player. Be aware that these same material plays perfectly with FLEX (need to know that PLEX has AC3 option off though).
HD (BluRay) material audio gets out of sync with video.
Media Player is not selecting the correct audio track. All of my movies have several audio tracks (DTS-lossless, AC3, DTS, english, french, spanish, etc.) I did this to have a flexibility of future applications and also some other systems like popcorn hour and ReQuest F3 Server have full support for these media. What the system is doing is selecting any audio track at random, sometimes it plays in other languages and some other times it even plays the directors commentaries. If the system is not able to do this automatically, at least give us the option to select the audio track prior to play to movie, similar to the flow that PLEX uses now.
System doesn’t have an option to correct Metadata (similar to Plex and XBMC have).
System shouldn’t show file name. We don’t care about file names, it should display Metadata information instead. This is done by other media players as well.
System doesn’t allow to have multiple shares by group. I have, and I am sure everybody have movies in different folders or locations. It will be best to allow a Movie container and in it we should have the options to point to multiple folders. This way we don’t end up with multiple movie locations in the Favorites instead of just seen one location.
AC3 and DTS is partially working. When these two options are on during HD (bluray) playback it works perfectly, but when using regular DVD material the systems goes mutes. By disabling both options, the audio comes back,but is is stereo only.
Harmony Remote support. I am currently using my Harmony 890 remote with my aTV2, but when using the media player the functions don’t work. I have to use the regular Apple Remote.
Auto expand option. I will be great to have regular 4:3 format to automatically expand to 16:9 format, same way as XBMC does it.
The software installation made PLEX disappear from the MENU and made XBMC constantly crash. I had to manually installed the night builds from both applications manually again.
FF not working at all. it just doesn’t work.
Chapters UI could be better. it would be nice to have the ability to FF by track by press-hold the down option and them the button bar should display the tracks and by pressing the right button it should move to the next track. This is how other media players work. I you want to get really fancy, then the best option will be to hold the center button and then display the icons for each chapter. Same way has the regular Apple interface works when renting movies.
ISO support. No ISO support, how can that be possible? This is the standard format for any high-end audio-video system.
I have many other suggestions, but for now I think these are the more critical ones.
As I said before the application has GREAT potential, and I know we are on Beta only, but I will be great if we get these glitches out of the way. to support the cause, I have purchased the lifetime membership version.
System configuration:
AppleTV 2nd Generation (black) with 4.3 with Build 8F455
3Com 48port 1GB managed switch connected to Applet TV and Thecus N5200XXX with 15TB of storage using two 1GB ports for load balancing and failover options enable.
Netgear DSL Router WNDR3700 with 1GB ports.
All network devices are in a 1GB only network.
