You’ve mentioned improvements to Couchsurfer in the changelog for beta 5 but I’m not given the option to update it in the ‘Manage Extras’ menu; it just says ‘Installed’. Does this mean I have to remove it and re-install to get the most recent improvements? or are all the improvements running server-side?
P.S. Well done guys! Over here in the UK the Apple TV 2 isn’t really worth buying (no Hulu or Netflix) UNTIL aTVFlash black is installed; then it is magnificent.
