best / fastest way to get content onto ATV Generation 1
I have acquired a JB ATV 1 with aTV Flash and many plugins installed. What’s the best / fastest way to get content onto the 160 GB internal drive ?
I have tried using FTP with Cyberduck via Wifi but it’s very very slow. Hard wired connection via RJ45 is a bit impractical because of where the device is located.
e.g 4 AVI files approx 4GB taking more than one hour.
WinSCP any faster than FTP?
I don’t use Windows - just Mac or Linux
WinSCP is utility, not protocol.
FTP or SMB  are fastest what you can get on it, ~10Mbs.
Connect it to wire and you will get your 4gb movie  in 5min.
WinSCP won’t run on Mac/Linux but similar such as Putty / Cyberduck will.
Even using hard wired lan cable, the speed sucks .
