Has anyone else noticed that the pause/play button on the lock screen is no longer working. It never pauses the audio. Also I have setup a timer with stop playing as the action at the end that used to stop the video which also no longer works. I suspect the two are linked.
Basically when I turn the ipad off and just have audio playing pressing the pause button doesn’t do anything anymore. I use this as a sleep timer. It used to work and still does with VLC but I don’t want to go back to that.
