AV1 hardware decoding (M3/A17 Pro)
Hi ! The new Apple silicon A17 pro, that comme with the iPhone 15 pro, as the support for av1 hardware decoding. Can we expect to have AV1 hdr (or Dolby vision) playback supported ?
It’s on our list of iOS 17 things we’re looking into. :slightly_smiling_face:
Hi ! I have an iPhone 15 pro max so if you need me to test things, I can
Would this allow for PiP on A17 Pro chips for AV1 videos?
I was wondering which deooder does fireCore uses for playback of AV1 Content?
The dav1d decoder from VIdeoLAN is really matured and also reached 1.0 recently, in vlc, firefox, chrome, we are able to decode 10bit 4k HDR videos without shuttering as uses more recent decoder and threading works very well,
I did not find any details of which decoder it uses under the hood, and on m1 pro 14", it is having choppy playback even if we have enough good hardware.
Why AV1 HDR playback is not supported on iOS and tv OS ?
Because apple doesn’t support hardware decoding of AV1
infuse Play av1 encoded hdr video without triggering hdr mode, still play in sdr mode, in windows with mpcbe can trigger hdr mode,Here is the metadata of the video
MediaInfo
概览
特征 ID : 94067515576208133852179422953697581033 (0x46C4BE97D45550F3BEE5A9C91DA217E9)
完整名称 : \192.168.31.244\d\视频\Man of Steel 2013 BluRay 2160p Atmos TrueHD7 1 AV1 10bit-CHD\Man of Steel 2013 BluRay 2160p Atmos TrueHD7 1 AV1 10bit-CHD.mkv
格式 : Matroska
格式版本 : Version 4 / Version 2
文件大小 : 28.6 GiB
时长 : 2 时 22 分
总体码率模式 : 动态码率 (VBR)
总体码率 : 28.7 Mb/s
编码日期 : UTC 2020-12-19 13:24:23
编码程序 : mkvmerge v51.0.0.46 (‘I Wish’) 64-bit
编码函数库 : libebml v1.4.0 + libmatroska v1.6.2
视频
格式 : AV1
格式/信息 : AOMedia Video 1
格式配置 (Profile) : Main@L5.0
HDR 格式 : SMPTE ST 2086, HDR10 compatible
编解码器 ID : V_AV1
时长 : 2 时 22 分
码率 : 20.3 Mb/s
宽度 : 3 840 像素
高度 : 1 600 像素
画面比例 : 2.40:1
帧率模式 : 恒定帧率 (CFR)
帧率 : 23.976 (24000/1001) FPS
色彩空间 : YUV
色度抽样 : 4:2:0
位深 : 10 位
数据密度 [码率/(像素*帧率)] : 0.138
流大小 : 20.2 GiB (71%)
Default : 是
Forced : 否
色彩范围 : Limited
色彩原色 : BT.2020
传输特性 : PQ
矩阵系数 : BT.2020 non-constant
制片显示器色彩原色 : Display P3
制片显示器亮度 : min: 0.0050 cd/m2, max: 4000 cd/m2
最大内容亮度 (CLL) : 7770
最大帧平均亮度 (FALL) : 1468
音频 #1
原始来源介质 ID : 4352 (0x1100)
格式 : MLP FBA 16-ch
格式/信息 : Meridian Lossless Packing FBA with 16-channel presentation
传播名 : Dolby TrueHD with Dolby Atmos
编解码器 ID : A_TRUEHD
时长 : 2 时 22 分
码率模式 : 动态码率 (VBR)
码率 : 5 428 kb/s
最大码率 : 8 757 kb/s
声道数 : 8 声道
声道格式 : L R C LFE Ls Rs Lb Rb
采样率 : 48.0 kHz
帧率 : 1 200.000 FPS (40 SPF)
压缩模式 : 无损
流大小 : 5.42 GiB (19%)
语言 : 英语 (English)
Default : 是
Forced : 否
原始来源介质 : Blu-ray
动态对象总数 : 11
音床声道数 : 1 声道
音床声道配置 : LFE
音频 #2
原始来源介质 ID : 4366 (0x110E)
格式 : DTS XLL
格式/信息 : Digital Theater Systems
传播名 : DTS-HD Master Audio
编解码器 ID : A_DTS
时长 : 2 时 22 分
码率模式 : 动态码率 (VBR) / 恒定码率 (CBR)
码率 : 2 776 kb/s / 1 509 kb/s
声道数 : 8 声道 / 6 声道
声道格式 : C L R LFE Lb Rb Lss Rss / C L R Ls Rs LFE
采样率 : 48.0 kHz
帧率 : 93.750 FPS (512 SPF)
位深 : 16 位
压缩模式 : 无损 / Lossy
流大小 : 2.77 GiB (10%)
语言 : 中文 (Chinese)
Default : 否
Forced : 否
原始来源介质 : Blu-ray
文本 #1
原始来源介质 ID : 4793 (0x12B9)
格式 : PGS
混流模式 : zlib
编解码器 ID : S_HDMV/PGS
编解码器 ID/信息 : Picture based subtitle format used on BDs/HD-DVDs
时长 : 2 时 14 分
码率 : 54.2 kb/s
帧率 : 0.485 FPS
元素总数 : 3923
流大小 : 52.3 MiB (0%)
标题 : CHS&ENG
语言 : 中文 (Chinese)
Default : 是
Forced : 否
原始来源介质 : Blu-ray
文本 #2
原始来源介质 ID : 4794 (0x12BA)
格式 : PGS
混流模式 : zlib
时长 : 2 时 14 分
码率 : 53.2 kb/s
帧率 : 0.485 FPS
元素总数 : 3923
流大小 : 51.4 MiB (0%)
标题 : CHT&ENG
语言 : 中文 (Chinese)
Default : 否
Forced : 否
原始来源介质 : Blu-ray
文本 #3
原始来源介质 ID : 4795 (0x12BB)
格式 : PGS
混流模式 : zlib
时长 : 2 时 14 分
码率 : 40.3 kb/s
帧率 : 0.444 FPS
元素总数 : 3595
流大小 : 38.9 MiB (0%)
标题 : CHS
语言 : 中文 (Chinese)
Default : 否
Forced : 否
原始来源介质 : Blu-ray
文本 #4
原始来源介质 ID : 4796 (0x12BC)
格式 : PGS
混流模式 : zlib
时长 : 2 时 14 分
码率 : 40.1 kb/s
帧率 : 0.444 FPS
元素总数 : 3595
流大小 : 38.7 MiB (0%)
标题 : CHT
语言 : 中文 (Chinese)
Default : 否
Forced : 否
原始来源介质 : Blu-ray
文本 #5
原始来源介质 ID : 4768 (0x12A0)
格式 : PGS
混流模式 : zlib
时长 : 2 时 22 分
码率 : 24.8 kb/s
帧率 : 0.345 FPS
元素总数 : 2940
流大小 : 25.2 MiB (0%)
标题 : ENG
语言 : 英语 (English)
Default : 否
Forced : 否
原始来源介质 : Blu-ray
菜单
00:00:00.000 : en:绗?01 绔燸
00:11:15.966 : en:绗?02 绔燸
00:20:00.449 : en:绗?03 绔燸
00:30:08.473 : en:绗?04 绔燸
00:39:20.608 : en:绗?05 绔燸
00:48:56.642 : en:绗?06 绔燸
00:59:02.413 : en:绗?07 绔燸
01:08:56.882 : en:绗?08 绔燸
01:17:34.107 : en:绗?09 绔燸
01:28:35.184 : en:绗?10 绔燸
01:40:46.790 : en:绗?11 绔燸
01:50:54.856 : en:绗?12 绔燸
02:00:52.578 : en:绗?13 绔燸
02:10:12.554 : en:绗?14 绔燸
02:12:48.919 : en:绗?15 绔燸
AV1 hardware decoding is available in today’s 7.7.2 update. :slightly_smiling_face:
