Automatically Set Audio Track?
Is it possible to automatically set audio track and no subtitles? I’ve got an anime I watch and first track is Japanese and second is English. I hate I keep having to change every episode. Help?
Infuse will try select the language track which matches the language setting on your device. However, if the video contains a track which is marked as default, Infuse will select that instead.
To avoid this, you can simply change the Settings > Language > Audio setting from Auto to English.
Additionally, you can change the Settings > Playback > Subtitles option to Off (or Forced Only) to have subtitles disabled by default.
