Automatic Frame Rate and Dynamic Range Switching Over HDMI (iPadOS)
It’d be awesome if Infuse supported automatic frame rate and dynamic range switching over HDMI on iPadOS.
Currently, you can manually switch between SDR and HDR modes in Settings, but frame rate cannot be changed from 60Hz.
This feature would work on all iPads with USB-C and was being investigated by Firecore in 2018.
It would be great to have frame rate matching. I use Infuse with an external display quite regularly and having 23.976 fps content displayed at 60 fps is not smooth. I found no way to force the tv to 23.976 fps.
