Auto scan?
Hello guys,
I remember that my Apple TV used to do an auto scan to all my library. How can enable that option again? I use GDrive.
In Settings > General
Metadata Fetching On
Embedded Metadata Off
In Settings > Sync
iCloud Sync On
Make sure the shares you want scanned are checked on the Settings > Library page.
This should get you what you’re asking. Infuse will sync when first launched. You can go to the Settings > Library and watch the status on the lefthand side. Once it says Last Update… it should be done.
Thanks mate,btw there’s a way to do it in background? Months ago I used to leave infuse opened in my Apple TV and it worked but not anymore.
Go to the settings in the ATV and go to General > Usage > Background App Refresh
Make sure Background app refresh is on and if you can make Infuse the only app turned on to use it.
