If my speaker setup is 2.1 via AVR, what audio option should i select? And does it matter which I pick?
AppleTV is set on Auto.
7.1, 5.1 or the 2.0?
Thanks.
Thanks.
HDMI select auto if you’re using optical the Dolby.
Oh, I meant under the Audio option while playing a video when you slide down on the remote. The different audio tracks.
