Audio Sync Issue with AirPods Max and Infuse Pro on Apple TV with SDR Content/Video
Hi everyone,
I’m seeking help on an odd audio sync issue I’m having when playing SDR content/video and using my AirPods Max with Infuse Pro on my Apple TV.
When I play HDR and Dolby Vision content/video, audio is perfectly in sync, however, when I play SDR content, the audio is out of sync. I’ve performed wireless audio sync through the Apple TV settings across various refresh rates and frame rates. This calibration fixed sync issues I was initially having across all apps, but I noticed with Infuse, audio is still out of sync. Other apps, like Netflix, Amazon Prime, Disney+ all play SDR content with audio synced, so the issue only resides with Infuse Pro. Match Frame Rate and Dynamic Range are set to on on the Apple TV as well and toggling it on/off doesn’t fix the issue.
Strangely, if I initially play the content through my home theatre speakers (Apple TV is connected to a Denon receiver which is connected to a Sony Bravia TV), and than switch to my AirPods Max while the video is still playing or paused, the audio is synced. If I exit the video, and than resume, audio is out of sync once again.
Given this pattern, I suspect the issue might be specific to Infuse Pro’s handling of SDR content when the AirPods Max is the initial audio output device. Has anyone else experienced similar problems or found a solution?
Thank you in advance for your help!
A post was merged into an existing topic: Audio Sync with Airpods Pro on Apple TV 4K
