Hi
in Media Player are you able to switch between audio channels? as i have a Chinese Blu-ray and it has 2 audio languages. is there a option to switch audio?
Hi
When playing a movie/TV episode, press and hold the Select button. Then select the Audio tab and select the audio track you wish to use from the list.
