Hey just updated to beta 6. The video plays perfectly so far on all the 720p mkv files i’ve tried. Audio is a different story. On some there is no sound, on others it plays it at what sounds like double or triple speed, and another portion play perfectly.
Below is what the player lists as the audio codec for the files. All the files were listed with the same audio codec.
ATSC A/52A (AC-3)
Audio was buggy (sounded slowed down) with this audio info:
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 1h 1mn
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Stream size : 169 MiB (11%)
and played perfectly with:
Audio
Format : AC-3
Codec ID : A_AC3
Duration : 46mn 7s
Bit rate : 384 Kbps
Channel(s) : 2 channels
Channel positions : L R
Stream size : 127 MiB (11%)
Language : English
and again sounded buggy (sped up) with:
Audio
Format : AC-3
Codec ID : A_AC3
Duration : 1h 12mn
Bit rate : 384 Kbps
Stream size : 199 MiB (9%)
Title : English
Language : English
My interpretation is that it doesn’t work properly with more channel positions? Let me know if i can give you any other info.
