"Audio Delay" feature does not work in infuse on its own in Apple TV 4K
Whenever I play any movie, I feel that the audio is coming early when playing a video in DV/HDR, so i set up +100ms (in positive) in “Audio delay” feature to make the audio sync with the face movement and it works great IN Apple TV 4K 2nd Gen.
But THERE IS AN ISSUE.
whenever I play/resume a movie, “audio delay” feature is already set to +100ms (from earlier/already played movie) but it feels like the “Audio delay” feature does not work on its own and in order for “audio delay” feature to work, I have to manually change the value up or down and bring back to +100ms and then the voice sync corrects itself.
It looks like “Delay Audio” does not work on its own and have to be manually turned on.
it would be great if this issue could be checked @james .
Device is Apple TV 4K 2nd gen.
Which version of tvOS and Infuse are you using?
What type of device are you using for audio?
Can you send in a report from your device and post the 5 digit code it gives you here?
