Audio bug on Vision Pro
I’m having issues with the audio in the Infuse app on my AVP when using my Aipods Pro 3s. Every now and tben I start watching something, currently The Expanse with 5.1 sound, and the audio starts fine but when I switch to one of the environments like Cinsma or Room the audio shifts and is heavily balanced to one side, and once sounded like it was behind me. If I switch back to window mode the audio goes back to normal, but goes to left or right if I go immersive with it again. Force quitting the app doesn’t fix it. Anyone else having this issue?
Can confirm this had happened to me recently, with built-in speaker and immersize environment. Reverted back to normal when exiting full screen.
@james How do we fill a bug report?
I have the same problem.
Audio in right ear is not balanced correct when using Immersive mode.
I have noticed this same issue pop up occasionally I when using 4XVR but not as frequently as it happens in infuse.
Try press and hold the Digital Crown until it re-centers your position in the immersive environment.
