junec
#1
I got a second-hand ATV2 today and before I attempt to jailbreak it I would like to know if it’s possible. The version numbers confuse me a bit.
In Settings > General > About, it says:
Apple TV Software 4.4 (3140)
OS Build Version 5.0 (9A334v)
Thanks for any advice!
It is possible but it is a tethered Jail Break
4.4 (iOS 5.0 - 9A334v) - tethered
junec
#3
Ok that’s what I thought! Thank you! I just wanted to make sure before I gave it a go.
junec
#4
A couple of questions:
Is this the guide I should be using? http://forum.firecore.com/topic/7279
And if so, do I use those versions of seas0npass and ifaith or the latest versions?
