ATV2 v.4.4.3 and 4.0 how to jailbreak
Hello!
I have two ATV2 one running 4.0 and the other 4.4.3.
What is the correct procedure to update to v5 and jailbreak:
Does the ATV2 has to be already updated to v5?
I already have the v5 file downloaded, can I use that file (pressing shift in Seasonpass), or do I need to download it again using Seasonpass?
In Windows 7 Seasonpass says that I need the latest version of iTunes, but I already have it, should I continue and do the restore manually opening iTunes?
This is a little bit confusing for me, I’ve jailbroken iPads and iPhones before, but never ATVs, sorry.
1st download ifaith and dump the blobs so you can always have the choice to go back since both your versions are untethered, but manily for the 4.4.3
2nd down loaded the season pass
3rd just click on itunes make sure it’s up to date
4th open season pass right click on create ipsw go down the list to version (it last on the list it has 206 in the sequence of numbers)
5th plug in your atv with only the micro usb
6th enjoy
4
Thank you for the tips clarence . They worked perfect for me.
